Inquire about the product installation and fixing methods
------Question for RUT301000700 Please Put your question below------
I purchased product 4703-RUT301000700-ND.
I need to mount it on a distribution panel.
Do you have mounting materials available?
Or do I need to purchase them separately?
Hello @lindanny3, welcome to the TechForum!
Mounting hardware is not included with 4703-RUT301000700-ND. The box contains the RUT301000700, power supply, Ethernet cable, quick start guide, and packaging only (page 6 of the datasheet).
The datasheet lists DIN rail and flat surface as the mounting options (page 5), and page 10 shows the protrusion measurements with a DIN rail attached.
Teltonika sells a compact DIN rail kit separately,
4703-PR5MEC11-ND, compact plastic DIN rail kit.
It mounts to a 35 mm DIN rail and includes two #6-32 x 3/16 Philips pan head screws (datasheet).
