How to mount ED-IPC3020-08320 (raspberry pi) in a my home lab?
hi i would like to know how can i moubt them ? is it compatble with din rail system ? if yes witch type ?
thanks you !
any other way to mount them would make me happy to … ( im using a standard server rack of 19" )
Welcome to the Technical Forum. The data I found just lists under installation to place it on a desk. They do not list any mounting instructions. I do not see din rail or even a server rack. Here is the documentation I found: ED-IPC3020 Datasheet-EN.pdf
Hello @jeangabriellaferte and @Verna_1353,
This is EDATEC Technical Support. Thank you, Verna, for providing the datasheet link—that is exactly the right document to reference.
To add some specific details regarding your mounting questions based on that documentation:
  1. DIN Rail Compatibility: Yes, the ED-IPC3020 is fully compatible with standard 35mm DIN rail systems (which is the most common type). You can mount it using a DIN rail clip attached to the mounting holes on the back of the case.
  2. 19" Server Rack: Since this is a compact device, the standard way to mount it in a 19" rack is to install a DIN rail mounting bar or a shelf inside your rack, and then clip the device onto it.
  3. Mechanical Details: You can find the precise distance of the mounting holes and the physical dimensions in the “Dimensions” section of the datasheet and hardware manual linked above.
Best regards, EDATEC Technical Support Team
