EDA Technology Co: Raspberry Pi OS
EDA Tech’s Raspberry Pi based devices can ship with a pre-installed Raspberry Pi or without depending on model number.
For devices shipped without a Raspberry Pi, you’ll need to provide your own and update your Raspberry Pi image to support EDA Tech’s product.
They have an appnote available: AN9 Use the device on standard Raspberry PI OS: Installing Raspberry PI OS
Which includes a helper scirpt to install the required firmware for your device:
curl -s https://apt.edatec.cn/bsp/ed-install.sh | sudo bash -s ‘product name’
For example the: ED-AIC2000
curl -s https://apt.edatec.cn/bsp/ed-install.sh | sudo bash -s aic_200w /aic_230w/aic_hq
Unofficial full list, see Installing Raspberry PI OS for updates.
  • ED-AIC2000
  • ED-AIC2100
  • ED-GWL2010
  • ED-GWL2010
  • ED-HMI2002
  • ED-HMI2020
  • ED-HMI2120
  • ED-HMI2220
  • ED-HMI2320
  • ED-HMI2630
  • ED-HMI3010
  • ED-HMI3020
  • ED-IPC2010
  • ED-IPC2010
  • ED-IPC2400
  • ED-IPC2600
  • ED-IPC3020
  • ED-CM4Sen
  • ED-SBC2300
Our Full list of Products: Industrial PCs | Electronic Components Distributor DigiKey
Regards,
Hello @RobertCNelson,
This is EDATEC Technical Support. Thank you for sharing these resources with the community.
To add to this information: Our products can often be configured with or without a pre-installed OS. For users who need to re-install the operating system or are setting up a device that arrived without one, we highly recommend referring to the specific User Manual for your device model on our official Documentation Center.
The User Manual for each product contains a dedicated chapter (usually titled “Installing OS”) that provides the most up-to-date, step-by-step guidance on:
  1. Downloading the correct OS file.
  2. Flashing the image (e.g., to eMMC or SD card).
  3. Installing the specific Firmware/BSP package required to support the hardware features.
You can find the specific manual for your device here: https://edatec.cn/docs/
(For a reference example, see the ED-IPC3630 installation guide here: https://edatec.cn/docs/ipc3630/um/6-installing-os/)
Best regards, EDATEC Technical Support Team
