Insulation material
------Question for 11367 Please Put your question below------
What is the insulation material?
Hello @edxnor
Part 11367 Kit comes with 6 different hook-up wires. The insulation material isn’t mentioned in the documentation, but the wires are marked “CSA TR-64” in the product image.
This means they follow the CSA TR-64 standard, which refers to thermoplastic-insulated wire, typically using PVC insulation.
For more technical details, you can also check out the characteristics of similar CSA standards like TR-64.
