INSULATION TUBE
Can you provide a part number by Alpha Wire for a Insulation tube 1,5 kV 22x0,7mm 155°C
Hello rjimenez, welcome to the TechForum,
Unfortunately I could not find anything that we carry.
Do you have a series in mind, or any other information?
Hi Karl,
Thanks for your reply.
I have attached datasheet, it seems to be a polyester fiber impregnated with acrylic resin.
In my BOM I just have this features: Insulation tube 155ºC 5,0x0,7mm.
Can you check attached information and let me know if you have the same or something similar?
Thanks in advanced.
Best regards.
Sorry, we do not carry anything like this.
There’s some listings here for dielectric-rated protective tube/sleeve materials with an ID in the 5mm range. Not a direct equivalent in most cases, but probably an upgrade in terms of product specification.
Ok, I’ll check them and I hope to find something for my project, thanks for your support.
Best regards.
I’d also check the temperature rating of the tubing if it’s going near components that can get warm. Heat-shrink tubing can be a nice option too when you need both insulation and a snug fit around the wire.
