Is it possible to use Photomicrosensors in a vacuum?
Question:
Block
Answer:
Photomicrosensors are not designed for use in a vacuum.
Block
Explanation:
The components used in Photomicrosensors (e.g. cord, plastic material, internal circuit components) cause outgassing (releasing gases from materials) in a vacuum. In addition, if the Photomicrosensors is used in a vacuum, there is a high possibility of overheating and failure due to insufficient heat dissipation.
Block
Quick tips
For detection of an object in a vacuum chamber, consider using the vacuum resistant fiber sensor head.
  • Can be used in high vacuum of 10 to 5 Pa.
  • Heat-resistant temperature 120°C type and 200°C type are available.
Vacuum resistant 01
Vacuum resistant 02
Product category
Sensors Photomicro Sensors|
Classification
Usage, Applications
Related keywords
Optical Sensor
Use in Vacuum
Fiber Sensor
Vacuum Resistant Fiber Head
Vacuum Chamber
E32-VF1
E32-VF4
E32-T51V 1M
E32-T54V 1M
E32-T84SV 1M
Block
Please visit the link below to see this product line on the Digi-Key website
Optical Sensors | Digi-Key Electronics
https://components.omron.com/us-en/faq/sensors/FAQE40020
