Is this really a 8mm thread standoff
------Question for HTSN-M3-8-6-2 Please Put your question below------
Is the thread part really 8mm?
I have been searching all over and wanted to make sure
Welcome to the forum.
The data sheet linked on the part page says this is an 8mm long (dimension L) M3 threaded spacer.
Thank you. This is only one of its kind I found. Every single other one is only 6mm. I didn’t understand why they only made them in 6mm until I found this.
If you can use a different color/material there are other options in stock.
https://www.digikey.com/short/3008fvtt
Including other variations opens up more options.
https://www.digikey.com/short/f572cqt4
