Are you working on the following and not sure which Chip Antenna to use?
- Bluetooth / Wi-Fi / Zigbee
- Wi-Fi / UNII 1-3
- GNSS
- Sub-GHz ISM Mounting Location Physical Size Small / Medium / Large
- Dual-Band
- Ultra Wide-Band
Try out Johanson’s comprehensive step-by-step chip antenna selection guide.
It’s an interactive, and easy-to-use tool to help you select the right chip antenna part number. It includes mounting guidelines as well.
Click on any of the part numbers to see the datasheet, s-parameters and more.
Try it out at: Mounting Guidelines Selection Info Optimization Process - Johanson Technology | DigiKey
