Engineer just dropped on my desk to install. question does this gateway have internal antenna or do i need to order antenna? using product with sensocon wireless sensor.
Hello randy4, welcome to the TechForum! Could you please provide the DigiKey part number or manufacturer part number? Are you referring to 2287-T0007242-ND?
yes 2287-T0007242-ND
According to the datasheet, yes. Here is the description: "The LoRaWAN, 3G/4G and GPS antennas
are integrated within the enclosure. For remote applications
and extra flexibility it also supports optional external LoRaWAN
and 3G/4G Antennas. "
Our application the sensors are within 5 miles. Do think i will need the optional external antenna
That’s a little harder to determine as that highly depends on the gain of the antenna and design. The data for the LorA antenna is on page 2 and it seems like it would support a five-mile radius based on initial research. However, this is usually for sub-urban areas or open terrain, typically. LoRa usually has a larger span in general. You can try utilizing it for that range, but if it’s more for an urban area, you may need a higher gain antenna to reach that range. Line of sight is usually more important for LoRa WAN too.
