Hello Everyone,
I have a use case for a small project that I am working on, for Livestock management (Cattle in particular).
I need some guidance for the right censor to buy that is based on LoRa protocol, both as a wearable and possibly implanted gear.
This censor should be able to track things like activity, rumination time, heat period etc for the cattle and then transmit the data to a gateway and a network server.
Thanks for the support.
Greetings,
Unfortunately I don’t think that we’ll have anything to offer at the level of abstraction that you’re message suggests: DigiKey carries a variety of LoRA modules, temperature sensors, motion sensors, GPS modules and other components from which a device capable of measuring and communicating livestock activity could possibly be built, but nothing as a finished-goods product that could simply be purchased and put directly to the intended use.
DigiKey also maintains a list of design service providers that may be able to assist you with product development if you cannot find a solution suited for your needs elsewhere on the market.
