Mix epoxy according to manufacturer’s instructions.
Mix ratio of STYCAST
Mix ratio by weight: 100-STYCAST 2850 to 4.5-CAT 11
Mix ratio by volume: 100-STYCAST 2850 to 9.5-CAT 11
Can same be found on DigiKey?
Hello @ankit,
Welcome to DigiKey’s Forum!
The manufacturer’s recommendation is to use the CAT 24LV according to the datasheet.
Mix ratios:
STYCAST 2850 : CAT 24LV
Weight
Ratio = 100 : 8
Volume
Ratio = 100 : 17.5
For CAT 11, we will need to get in contact with the manufacturer for a ratio confirmation. Please note that this may take a few days for the manufacturer to respond. I will notify you once they have.
Thank you,
Victoria
Hi Thank you for the update. I realize I may not have clearly explained my question.
I urgently need to know how I can purchase 2,850 ft of CAT 11. Can I buy the same from www.digikey.in?
What can I update customer need 2850 ft with Cat 11 any suggestion? Being mnc cant suggest them to change material. Can you ask Loctite to help us out ? As This will be huge demand.
The Henkel website shows LOCTITE® STYCAST 2850 FT BLK and in the description of that it states that it is compatible with and can be used with LOCTITE® catalysts (or hardeners) CAT 9, CAT 11, CAT 23LV, and CAT 24LV.
There is a technical document for LOCTITE® STYCAST 2850FT CAT 11 so it maybe orderable but it would have to be by a special order non catalogue quote request.
If you want to proceed with trying for the non catalogue quote on the LOCTITE® STYCAST 2850FT CAT 11 please email non-cats@digikey.com
Hope that helps.
