Looking for a replacement for an IC Labeled Y8031 in a UK device
This is an IC used in a circuit for sequencing LED light strings
Typ in the Subject: Y803A
Hello @glenn5055
Welcome to the TechForum
That IC chip is part number R1172N401B-TR-FE from Nisshinbo Micro Devices
Hi glenn5055,
That’s a very specialized chip designed for that application. We would have nothing like it. One can build lighting controllers with similar functionalities, but this would require writing quite a bit of code and hardware design work.
Here are a few links which might help inspire:
https://maker.pro/arduino/projects/christmas-light-show-with-arduino
Thanks for the work you did! As this is not either critical or high dollar value, I will not repair it.
And thanks for the hints on a more advanced project for myself!
