Looking for a replacement for this tactile switch
I’m looking for a tactile switch replacement. The switch connector are two flat plates that are bent upwards at a 45 degree angle.
I’ve attached a picture of the current switch for reference.
Measurements are roughly 4.27mm x 3mm and the height with the button measured is 2.31mm and 2mm without.
I found some Omron tactile switches, but the connector where you would solder it onto the PCB is flat instead of angled upwards at a 45 degree angle. I cannot find anything similar with the upward angle connector.
Take a look at this link to see if any would work in your application.
