Looking for ACES board-to-board connector and extension solution
Hi,
I’m trying to identify and source the exact board-to-board connector shown in the attached images. The connector is manufactured by ACES and is used to connect a daughterboard to the mainboard in a compact embedded system.
What I need:
  • The exact part number or series of this ACES connector
  • OR a compatible extension solution (e.g. extension cable with adapter boards) that fits this type of connector
What is the center-to-center pitch from pin to pin dimension? This part if we have a compatible option would be under this section here
Hi, thanks for the quick reply
I’m not entirely sure about the pitch because it looks very small. Could it be 0.35 mm?
Sorry for the late response. I didnt see that you responded.
For 0.35mm these https://www.digikey.com/en/products/filter/arrays-edge-type-mezzanine-board-to-board/308?s=N4IgjCBcoEwBxVAYygMwIYBsDOBTANCAPZQDaIALAAwUDsAnAMwgC6hADgC5QgDKnAJwCWAOwDmIAL6E4CaCBSQMOAsTIgYAVgr0YzNiC49%2Bw8VJn1ECtFjyESkchThgYrDt0h9BoiZP9AA are the closest options.
