Looking for other connector on a Raven Module
Good Day
For a Raven Module I am looking for the other connector to to plug into it I have 5810130029 and need the other connector part number as well.
Raven Module Part number 10630173031
The pins too please.
Thanks
Hello, Timothy. Welcome to TechForum!
We have a few options for mating device for this connector, here: Cinch Connectivity Solutions 30 Headers. Nothing cable-to-cable unfortunately, that does not seem to be how the system is designed. Might one of these work?
What I am looking for is what plugs into the Raven Module 10630173031
I see, my apologies.
Unfortunately, we don’t have access to OEM schematics for this module and I’m having trouble running down any reliable information for it online. Do you have images, documents or other information on this product I can use to try and run it down for you?
I hope this picture helps
Thank you!
Please check the list of options provided above for mates to this device. One of them will hopefully align with your needs, as unfortunately I cannot find reliable images of the Raven device to check against our stock at this time.
I don’t want the mate.
I would like a connector like this please.
I’m sorry, I’m not sure I understand? The device you’ve depicted shows up easily in our system under the number 5810130029 that you gave, here: 5810130029 Cinch Connectivity Solutions. Is this the product you’re after?
Which connector is this one as it may been switch in my shop
Hello, Timothy. Please check this link provided above, and see if it fits your needs.
The link is not letting me in
If the link isn’t working you can also check the part directly from our website. Open this DigiKey link and search DigiKey part number 116-1111-ND
Thank you, the second picture matches up to the part number. 116-1111-ND
But the first picture is different and looking for that number now.
Thank you for your time
I have figured the other connector I was looking for is 5810130028
timothy.schweigert,
I’m glad you found the part number you were looking for.
Let us know if there is anything else we can assist with.
Good luck with the repairs.
