To my knowledge, capacitance is not typically called out on switch or relay datasheets.
As a conversation starting point, have you considered using a hermetically sealed relay such as this?
You can find the manufacturer’s data here:
Depending on your application, you may be able to uses solid state solution in the form of a PIN diode. Here is a brief introduction using a common1N4148 diode as an example:
Please let us know if we can be of further assistance. If you do, please respond with additional information such as the power level associated with your circuit.
