------Question for AFBR-S6EPY12251R Please Put your question below------
Is the manufacturing date after 2024?
Hello @bhjung2010 ,
Thank you for your query!
Unfortunately, we are unable to provide specific date codes of what we have in stock prior to shipment.
However, If you require the Date code to be within a specific time you could specify those requirements in the order notes at the time of order.
If the date code is in your order notes, our warehouse will fill your order with the appropriate stock. And if that is not possible, our customer service team will contact you to see if the date code we do have is acceptable by you or if you would like to cancel that part of the order.
Please refer the following link for more details on Specific Date Code Requirements & Lot Code Requests
