There are also a fair number of integrated DC-DC converters available for performing the 5-to-+/-15V trick. A drop-in replacement for a control IC of the sort mentioned they’re not, but depending on the circumstances it’s potentially a more convenient/economical approach.
if you can show some of those DC-DC converters that do the 5-to-+/-15V that would also be really helpful i can’t seem to find any that give both a positive and negative output
Pretty much all of the parts in Rick’s link produce both + and - 15V from a 5V source. I noticed that the typical applications for the MAX742 were fairly high powered, as in the 6W to 22W range. Assuming you need something with that sort of capability, here is a shortlist from Rick’s list which are in that sort of output range:
