If you are looking for the meaning of “C1” in the TE ES2000-NO.1-C1-0-27MM Heat Shrink, here is the clarification from the manufacturer:
The suffix “C1” in the part number ES2000-NO.1-C1-0-27MM from TE Connectivity’s Raychem series typically indicates a specific characteristic or feature of the product. In this case, it refers to the color of the heat shrink tubing, which is black.
Applicable Part Numbers
| ES2000-NO.1-C1-0-STK-ND | ES2000-NO.1-C1-0-STK |
| ES2000-NO.1-C1-0-27MM-ND | ES2000-NO.1-C1-0-27MM |
| ES2000-NO.1-C1-0-50MM-ND | ES2000-NO.1-C1-0-50MM |
| ES2000-NO.1-C1-0-15MM-ND | ES2000-NO.1-C1-0-15MM |
| ES2000-NO.1-C1-0-20MM-ND | ES2000-NO.1-C1-0-20MM |
| ES2000-NO.1-C1-0-21MM-ND | ES2000-NO.1-C1-0-21MM |
| ES2000-NO.1-C1-0-25MM-ND | ES2000-NO.1-C1-0-25MM |
| ES2000-NO.1-C1-0-30MM-ND | ES2000-NO.1-C1-0-30MM |
| ES2000-NO.1-C1-0-35MM-ND | ES2000-NO.1-C1-0-35MM |
| ES2000-NO.1-C1-0-38MM-ND | ES2000-NO.1-C1-0-38MM |
| ES2000-NO.1-C1-0-40MM-ND | ES2000-NO.1-C1-0-40MM |
| ES2000-NO.1-C1-0-45MM-ND | ES2000-NO.1-C1-0-45MM |
| ES2000-NO.1-C1-0-60MM-ND | ES2000-NO.1-C1-0-60MM |
| ES2000-NO.1-C1-0-63MM-ND | ES2000-NO.1-C1-0-63MM |
| ES2000-NO.1-C1-0-65MM-ND | ES2000-NO.1-C1-0-65MM |
| ES2000-NO.1-C1-0-80MM-ND | ES2000-NO.1-C1-0-80MM |
| ES2000-NO.1-C1-0-95MM-ND | ES2000-NO.1-C1-0-95MM |
| ES2000-NO.1-C1-0-110MM-ND | ES2000-NO.1-C1-0-110MM |
| ES2000-NO.1-C1-0-100MM-ND | ES2000-NO.1-C1-0-100MM |
| ES2000-NO.1-C1-0-COIL-ND | ES2000-NO.1-C1-0-COIL |
