I am trying to find female snap-in ecg connectors similar to these 3.5mm 4.0mm ECG Snap socket,PCB Mount ECG Snap socket manufacturer,SMT SMD Type ECG Snap socket supplier,China factory price Female ecg snap button connector used for connecting ECG electrodes. I am having a hard time finding a similar product on DigiKey and was wondering if anyone has had luck sourcing these snap-in connectors.
I am specifically looking for a Female Snap Socket that can be soldered directly to a board (SMT/SMD preferred, but Thru-Hole is also fine, same with a soldered wire).
Desired Specifications:
Mating Size: Compatible with standard 3.5mm or 4.0mm medical snap studs.
Mounting Type: PCB Mount (Surface Mount or Thru-Hole, or wire connection).
Application: ECG/EKG
I have seen these referred to as “3.5mm/4.0mm ECG Snap Sockets” or “PCB Mount Snap Buttons” from overseas manufacturers, but I’m looking for something stocked at DigiKey (e.g., from manufacturers like Keystone Electronics or similar).
Does DigiKey carry any individual snap connectors or that fit this description?
Thank you for the help!
