Need help finding part, IDE connector
Hi!
Need help finding this part in the DIGIKEY stock.
Its some kind of IDE connector i think.
Kind Regards
Mikael
Hello flockisson, Welcome to the DigiKey TechForum.
If you are looking for one with all 40 pins, for mounting through the board, with a 0.1" spacing of the leads, and the 2 rows, Click here for possible matches.
These have gold plating on the pins, and the picture looks to have a gold color.
Please check the datasheets to verify compatibility to your application.
Looks like the ones from 3M are the closest matches.
Thank you very much!
Hello Mikael,
Watch out for the indexing pin.
You will likely need to pull this pin from the new socket.
Sometime a little persuasion from a soldering iron is required.
Best Wishes,
