Can any one help me on find this micr sd card reader, which is solder to the board. It had a metal piece on top which put pressure on the sc card to hold it on place. As you could see on of the pins is broken off.
Hello @desorden82
While I wasn’t able to verify the exact number for that connector, please take a look at the WM6698CT-ND and 2073-MEM2067-02-180-00-ACT-ND on the following link:
https://www.digikey.com/short/ppjrz8
Sincerely,
Justin
Thank you so much. I just made an order.
