If you are looking for soldering reflow details for the MT41K256M16TW-107 IT:P TR SDRAM from Micron Technology Inc., please refer to the details below.
The reflow temperature profile is one of the most important factors in surface mount component assembly and must be fine-tuned to establish a robust process for solder joint formation. The actual temperature of the board or components will be different from the reflow oven setting and is dependent on several factors, including board size, thermal mass, component density, oven type, solder type, reflow oven, and so on. The other reflow parameters such as heating ramp rate, dwell time, and cooling rate should be selected depending on the flux activity/chemistry being used and should closely follow the paste manufacturer’s recommendations.
It is the responsibility of the user to properly measure the temperature at different locations on the PCB and components to ensure the desired temperature is reached at all locations for complete reflow of solder joint. Typical examples of reflow profile are shown in Figure 7 with peak temperatures of 260°C, 235°C, and 220°C, depending on the application and solder paste type.
Please refer to the document below for more details:
csn33-bga-user-guide.pdf (986.2 KB)
Applicable Part Numbers
| 557-1720-ND | MT41K256M8DA-125:K |
| 557-1792-ND | MT41K256M16TW-107:P |
| MT41K256M16TW-093:P-ND | MT41K256M16TW-093:P |
| 557-2010-2-ND,557-2010-1-ND,557-2010-6-ND | MT41K64M16TW-107:J TR |
| 557-1765-ND | MT41K64M16TW-107:J |
| 557-2003-2-ND,557-2003-1-ND,557-2003-6-ND | MT41K128M8DA-107:J TR |
| 557-MT41K512M8DA-107:PTR-ND,557-MT41K512M8DA-107:PTRCT-ND,557-MT41K512M8DA-107:PTRDKR-ND | MT41K512M8DA-107:P TR |
| 557-2004-2-ND,557-2004-1-ND,557-2004-6-ND | MT41K128M8DA-107 IT:J TR |
| MT41K64M16TW-107IT:J-ND | MT41K64M16TW-107 IT:J |
| 557-1743-2-ND,557-1743-1-ND,557-1743-6-ND | MT41K64M16TW-107 AIT:J TR |
| MT41K64M16TW-107AIT:J-ND | MT41K64M16TW-107 AIT:J |
| 557-1895-2-ND,557-1895-1-ND,557-1895-6-ND | MT41K128M16JT-125 IT:K TR |
| 557-1764-ND | MT41K512M8DA-107:P |
| 557-1894-2-ND,557-1894-1-ND,557-1894-6-ND | MT41K128M16JT-125 AIT:K TR |
| 557-1759-ND | MT41K256M8DA-125 AIT:K |
| 557-1752-ND | MT41K128M16JT-125 AIT:K |
| 557-MT41K512M8DA-107IT:PTR-ND,557-MT41K512M8DA-107IT:PTRCT-ND,557-MT41K512M8DA-107IT:PTRDKR-ND | MT41K512M8DA-107 IT:P TR |
| MT41K512M8DA-107IT:P-ND | MT41K512M8DA-107 IT:P |
| 557-MT41K256M16TW-107IT:PTR-ND,557-MT41K256M16TW-107IT:PTRCT-ND,557-MT41K256M16TW-107IT:PTRDKR-ND | MT41K256M16TW-107 IT:P TR |
| MT41K256M16TW-107IT:P-ND | MT41K256M16TW-107 IT:P |
| 557-1751-ND | MT41K128M16JT-125 AAT:K |
| 557-1897-2-ND,557-1897-1-ND,557-1897-6-ND | MT41K256M8DA-125 AIT:K TR |
| 557-2005-2-ND,557-2005-1-ND,557-2005-6-ND | MT41K256M16TW-107 AIT:P TR |
| 557-1756-ND | MT41K256M16TW-107 AIT:P |
| 557-MT41K128M16JT-125AAT:KTR-ND,557-MT41K128M16JT-125AAT:KTRCT-ND,557-MT41K128M16JT-125AAT:KTRDKR-ND | MT41K128M16JT-125 AAT:K TR |
| 557-1741-2-ND,557-1741-1-ND,557-1741-6-ND | MT41K256M16TW-107 AAT:P TR |
| 557-MT41K256M16TW-107AAT:P-ND | MT41K256M16TW-107 AAT:P |
| 557-1761-ND | MT41K512M8DA-107 AAT:P |
| MT41K256M16TW-107AUT:P-ND | MT41K256M16TW-107 AUT:P |
| 557-2006-2-ND,557-2006-1-ND,557-2006-6-ND | MT41K256M16TW-107 XIT:P TR |
| 557-MT41K512M16VRP-107IT:P-ND | MT41K512M16VRP-107 IT:P |
| 557-MT41K512M16VRP-107AAT:P-ND | MT41K512M16VRP-107 AAT:P |
| 557-MT41K512M16VRP-107AAT:PTR-ND,557-MT41K512M16VRP-107AAT:PTRCT-ND,557-MT41K512M16VRP-107AAT:PTRDKR-ND | MT41K512M16VRP-107 AAT:P TR |
| 557-1753-ND | MT41K128M16JT-125 XIT:K |
| 557-1757-ND | MT41K256M16TW-107 XIT:P |
| 557-MT41K256M8DA-125IT:KTR-ND,557-MT41K256M8DA-125IT:KTRCT-ND,557-MT41K256M8DA-125IT:KTRDKR-ND | MT41K256M8DA-125 IT:K TR |
| MT41K128M16JT-107IT:K-ND | MT41K128M16JT-107 IT:K |
| 557-1893-2-ND,557-1893-1-ND,557-1893-6-ND | MT41K128M16JT-107 IT:K TR |
| MT41K128M8DA-107IT:J-ND | MT41K128M8DA-107 IT:J |
| MT41K256M8DA-125IT:K-ND | MT41K256M8DA-125 IT:K |
| 557-1719-ND | MT41K128M8DA-107:J |
| MT41K64M16TW-107AAT:J-ND | MT41K64M16TW-107 AAT:J |
| MT41K64M16TW-107AUT:J-ND | MT41K64M16TW-107 AUT:J |
| 557-MT41K256M16TW-107:PTR-ND,557-MT41K256M16TW-107:PTRCT-ND,557-MT41K256M16TW-107:PTRDKR-ND | MT41K256M16TW-107:P TR |
| MT41K128M16JT-107AAT:K-ND | MT41K128M16JT-107 AAT:K |
| 557-2007-2-ND,557-2007-1-ND,557-2007-6-ND | MT41K512M8DA-107 AAT:P TR |
| 557-MT41K128M16JT-125AUT:KTR-ND,557-MT41K128M16JT-125AUT:KTRCT-ND,557-MT41K128M16JT-125AUT:KTRDKR-ND | MT41K128M16JT-125 AUT:K TR |
| 557-MT41K256M16TW-107AUT:PTR-ND,557-MT41K256M16TW-107AUT:PTRCT-ND,557-MT41K256M16TW-107AUT:PTRDKR-ND | MT41K256M16TW-107 AUT:P TR |
| 557-MT41K512M16VRP-107AIT:P-ND | MT41K512M16VRP-107 AIT:P |
| MT41K64M16TW-107XIT:J-ND | MT41K64M16TW-107 XIT:J |
| MT41K256M8DA-107:K-ND | MT41K256M8DA-107:K |
| MT41K128M16JT-107:K-ND | MT41K128M16JT-107:K |
| MT41K512M8DA-093:P-ND | MT41K512M8DA-093:P |
| MT41K128M16JT-125IT:K-ND | MT41K128M16JT-125 IT:K |
| 557-1742-2-ND,557-1742-1-ND,557-1742-6-ND | MT41K64M16TW-107 AAT:J TR |
| 557-MT41K256M8DA-125:KTR-ND,557-MT41K256M8DA-125:KTRCT-ND,557-MT41K256M8DA-125:KTRDKR-ND | MT41K256M8DA-125:K TR |
| 557-MT41K128M16JT-107:KTR-ND,557-MT41K128M16JT-107:KTRCT-ND,557-MT41K128M16JT-107:KTRDKR-ND | MT41K128M16JT-107:K TR |
| 557-MT41K256M16TW-093:PTR-ND,557-MT41K256M16TW-093:PTRCT-ND,557-MT41K256M16TW-093:PTRDKR-ND | MT41K256M16TW-093:P TR |
| 557-MT41K64M16TW-107XIT:JTR-ND,557-MT41K64M16TW-107XIT:JTRCT-ND,557-MT41K64M16TW-107XIT:JTRDKR-ND | MT41K64M16TW-107 XIT:J TR |
| MT41K256M8DA-107AAT:K-ND | MT41K256M8DA-107 AAT:K |
| 557-MT41K256M8DA-107AAT:KTR-ND,557-MT41K256M8DA-107AAT:KTRCT-ND,557-MT41K256M8DA-107AAT:KTRDKR-ND | MT41K256M8DA-107 AAT:K TR |
| 557-MT41K128M16JT-125AUT:K-ND | MT41K128M16JT-125 AUT:K |
| 557-MT41K128M16JT-125XIT:KTR-ND,557-MT41K128M16JT-125XIT:KTRCT-ND,557-MT41K128M16JT-125XIT:KTRDKR-ND | MT41K128M16JT-125 XIT:K TR |
| MT41K1G8RKB-107:P-ND | MT41K1G8RKB-107:P |
| 557-MT41K1G8RKB-107:PTR-ND,557-MT41K1G8RKB-107:PTRCT-ND,557-MT41K1G8RKB-107:PTRDKR-ND | MT41K1G8RKB-107:P TR |
| 5736-MT41K512M16VRN-107IT:PTR-ND | MT41K512M16VRN-107 IT:P TR |
| 5736-MT41K1G8SN-125:ATR-ND | MT41K1G8SN-125:A TR |
| 557-MT41K128M16JT-125:KTR-ND,557-MT41K128M16JT-125:KTRCT-ND,557-MT41K128M16JT-125:KTRDKR-ND | MT41K128M16JT-125:K TR |
| 557-MT41K64M16TW-107IT:JTR-ND,557-MT41K64M16TW-107IT:JTRCT-ND,557-MT41K64M16TW-107IT:JTRDKR-ND | MT41K64M16TW-107 IT:J TR |
| 557-2008-2-ND,557-2008-1-ND | MT41K512M8DA-107 AIT:P TR |
| MT41K128M16JT-125:K-ND | MT41K128M16JT-125:K |
| MT41K512M8DA-093:PTR-ND | MT41K512M8DA-093:P TR |
| MT41K256M8DA-107:KTR-ND | MT41K256M8DA-107:K TR |
| MT41K256M16V00HWC1-ND | MT41K256M16V00HWC1 |
| MT41K512M4DA-125:KTR-ND | MT41K512M4DA-125:K TR |
| 557-1739-2-ND,557-1739-1-ND,557-1739-6-ND | MT41K128M8DA-107 AIT:J TR |
| MT41K64M16TW-107AUT:JTR-ND | MT41K64M16TW-107 AUT:J TR |
| MT41K256M4DA-107:JTR-ND | MT41K256M4DA-107:J TR |
| MT41K128M16JT-107AAT:KTR-ND | MT41K128M16JT-107 AAT:K TR |
| MT41K256M16HA-107:ETR-ND | MT41K256M16HA-107:E TR |
| MT41K256M16HA-107G:ETR-ND | MT41K256M16HA-107G:E TR |
| MT41K256M16HA-125:ETR-ND | MT41K256M16HA-125:E TR |
| MT41K512M8RH-107:ETR-ND | MT41K512M8RH-107:E TR |
| MT41K512M8RH-125:ETR-ND | MT41K512M8RH-125:E TR |
| MT41K128M8JP-125:GTR-ND | MT41K128M8JP-125:G TR |
| MT41K128M16V89C3WC1-ND | MT41K128M16V89C3WC1 |
| MT41K256M16HA-125M:ETR-ND | MT41K256M16HA-125 M:E TR |
| MT41K128M16JT-125M:KTR-ND | MT41K128M16JT-125 M:K TR |
| 557-1762-ND | MT41K512M8DA-107 AIT:P |
| MT41K1G4RH-125:ETR-ND | MT41K1G4RH-125:E TR |
| MT41K256M4JP-125:G-ND | MT41K256M4JP-125:G |
| MT41K512M8V00HWC1-ND | MT41K512M8V00HWC1 |
| MT41K256M16HA-107IT:ETR-ND | MT41K256M16HA-107 IT:E TR |
| MT41K256M16HA-125IT:ETR-ND | MT41K256M16HA-125 IT:E TR |
| MT41K512M8RH-125IT:ETR-ND | MT41K512M8RH-125 IT:E TR |
| MT41K512M8RG-107:NTR-ND | MT41K512M8RG-107:N TR |
| MT41K512M8DA-107V:PTR-ND | MT41K512M8DA-107 V:P TR |
| MT41K512M8DA-107V:P-ND | MT41K512M8DA-107 V:P |
| 557-1758-ND | MT41K256M8DA-125 AAT:K |
| MT41K512M8RG-093:NTR-ND | MT41K512M8RG-093:N TR |
| 557-1896-2-ND,557-1896-1-ND | MT41K256M16LY-107:N TR |
| MT41K512M8RH-125M:ETR-ND | MT41K512M8RH-125 M:E TR |
| 557-2009-2-ND,557-2009-1-ND,557-2009-6-ND | MT41K512M8DA-107 XIT:P TR |
| MT41K1G4RH-107:ETR-ND | MT41K1G4RH-107:E TR |
| 557-MT41K512M16VRP-107AIT:PTR-ND | MT41K512M16VRP-107 AIT:P TR |
| 557-MT41K512M16VRP-107IT:PTR-ND | MT41K512M16VRP-107 IT:P TR |
| MT41K512M16VRN-107AIT:PTR-ND | MT41K512M16VRN-107 AIT:P TR |
| MT41K512M16VRN-107AIT:P-ND | MT41K512M16VRN-107 AIT:P |
| MT41K512M16VRN-107AAT:PTR-ND | MT41K512M16VRN-107 AAT:P TR |
| MT41K512M16VRN-107AAT:P-ND | MT41K512M16VRN-107 AAT:P |
| MT41K1G8RKB-107:NTR-ND | MT41K1G8RKB-107:N TR |
| MT41K512M4HX-187E:D-ND | MT41K512M4HX-187E:D |
| MT41K1G8TRF-107:ETR-ND | MT41K1G8TRF-107:E TR |
| MT41K1G8TRF-125:ETR-ND | MT41K1G8TRF-125:E TR |
| MT41K512M16TNA-125:ETR-ND | MT41K512M16TNA-125:E TR |
| MT41K1G8SN-107IT:ATR-ND | MT41K1G8SN-107 IT:A TR |
| MT41K512M16TNA-125M:ETR-ND | MT41K512M16TNA-125 M:E TR |
| MT41K1G8TRF-125IT:ETR-ND | MT41K1G8TRF-125 IT:E TR |
| MT41K512M16TNA-125IT:ETR-ND | MT41K512M16TNA-125 IT:E TR |
| MT41K2G4TRF-125:ETR-ND | MT41K2G4TRF-125:E TR |
| MT41K2G4TRF-107:ETR-ND | MT41K2G4TRF-107:E TR |
| MT41K1G8THE-15E:DTR-ND | MT41K1G8THE-15E:D TR |
| MT41K128M16HA-15E:D-ND | MT41K128M16HA-15E:D |
| MT41K128M16HA-187E:D-ND | MT41K128M16HA-187E:D |
| MT41K256M4JP-15E:G-ND | MT41K256M4JP-15E:G |
| MT41K256M8HX-15E:D-ND | MT41K256M8HX-15E:D |
| MT41K256M8HX-187E:D-ND | MT41K256M8HX-187E:D |
| MT41K512M4HX-15E:D-ND | MT41K512M4HX-15E:D |
| MT41K128M16HA-15EIT:D-ND | MT41K128M16HA-15E IT:D |
| MT41K1G4THD-15E:D-ND | MT41K1G4THD-15E:D |
| MT41K1G4THD-187E:D-ND | MT41K1G4THD-187E:D |
| MT41K128M8JP-15E:G-ND | MT41K128M8JP-15E:G |
| MT41K1G4THV-125:M-ND | MT41K1G4THV-125:M |
| MT41K1G4THV-15E:M-ND | MT41K1G4THV-15E:M |
| MT41K256M16RE-15EIT:D-ND | MT41K256M16RE-15E IT:D |
| MT41K256M8DA-125:M-ND | MT41K256M8DA-125:M |
| MT41K256M8DA-15E:M-ND | MT41K256M8DA-15E:M |
| MT41K512M4DA-125:M-ND | MT41K512M4DA-125:M |
| MT41K512M8THD-15E:D-ND | MT41K512M8THD-15E:D |
| MT41K256M16HA-107:E-ND | MT41K256M16HA-107:E |
| MT41K512M8RH-107:E-ND | MT41K512M8RH-107:E |
| MT41K1G8THE-15E:D-ND | MT41K1G8THE-15E:D |
| MT41K256M16HA-125IT:E-ND | MT41K256M16HA-125 IT:E |
| MT41K512M8RH-125IT:E-ND | MT41K512M8RH-125 IT:E |
| MT41K256M16HA-125:E-ND | MT41K256M16HA-125:E |
| MT41K512M8RH-125:E-ND | MT41K512M8RH-125:E |
| MT41K256M16HA-107IT:E-ND | MT41K256M16HA-107 IT:E |
| MT41K256M16HA-107G:E-ND | MT41K256M16HA-107G:E |
| MT41K256M16HA-125AIT:E-ND | MT41K256M16HA-125 AIT:E |
| MT41K256M16HA-125MAIT:E-ND | MT41K256M16HA-125 M AIT:E |
| MT41K256M16HA-125M:E-ND | MT41K256M16HA-125 M:E |
| MT41K128M16JT-107G:KTR-ND | MT41K128M16JT-107G:K TR |
| MT41K128M16JT-125MAIT:KTR-ND | MT41K128M16JT-125 M AIT:K TR |
| MT41K256M16HA-125AIT:ETR-ND | MT41K256M16HA-125 AIT:E TR |
| MT41K256M16HA-125MAIT:ETR-ND | MT41K256M16HA-125 M AIT:E TR |
| MT41K256M4JP-15E:GTR-ND | MT41K256M4JP-15E:G TR |
| MT41K512M8RH-125AIT:ETR-ND | MT41K512M8RH-125 AIT:E TR |
| MT41K64M16JT-125:GTR-ND | MT41K64M16JT-125:G TR |
| MT41K64M16JT-15E:GTR-ND | MT41K64M16JT-15E:G TR |
| MT41K128M16JT-107G:K-ND | MT41K128M16JT-107G:K |
| 557-1718-ND | MT41K128M16JT-125 M AIT:K |
| MT41K128M16JT-125M:K-ND | MT41K128M16JT-125 M:K |
| MT41K1G4RH-107:E-ND | MT41K1G4RH-107:E |
| MT41K1G4RH-125:E-ND | MT41K1G4RH-125:E |
| MT41K1G8TRF-107:E-ND | MT41K1G8TRF-107:E |
| MT41K1G8TRF-125IT:E-ND | MT41K1G8TRF-125 IT:E |
| MT41K1G8TRF-125:E-ND | MT41K1G8TRF-125:E |
| MT41K2G4TRF-107:E-ND | MT41K2G4TRF-107:E |
| MT41K2G4TRF-125:E-ND | MT41K2G4TRF-125:E |
| MT41K512M16TNA-125IT:E-ND | MT41K512M16TNA-125 IT:E |
| MT41K512M16TNA-125M:E-ND | MT41K512M16TNA-125 M:E |
| MT41K512M16TNA-125:E-ND | MT41K512M16TNA-125:E |
| MT41K512M4DA-107:K-ND | MT41K512M4DA-107:K |
| 557-1721-ND | MT41K512M4DA-125:K |
| MT41K512M8RH-107IT:E-ND | MT41K512M8RH-107 IT:E |
| MT41K512M8RH-125AIT:E-ND | MT41K512M8RH-125 AIT:E |
| MT41K512M8RH-125M:E-ND | MT41K512M8RH-125 M:E |
| MT41K64M16JT-125:G-ND | MT41K64M16JT-125:G |
| MT41K64M16JT-15E:G-ND | MT41K64M16JT-15E:G |
| MT41K256M16HA-125XIT:E-ND | MT41K256M16HA-125 XIT:E |
| MT41K128M8JP-125:G-ND | MT41K128M8JP-125:G |
| MT41K256M4DA-107:J-ND | MT41K256M4DA-107:J |
| MT41K512M8RH-125XIT:E-ND | MT41K512M8RH-125 XIT:E |
| MT41K512M8RH-125AAT:E-ND | MT41K512M8RH-125 AAT:E |
| 557-1754-ND | MT41K1G4DA-107:P |
| 557-1755-ND | MT41K1G8SN-125:A |
| 557-1760-ND | MT41K512M16HA-125:A |
| MT41K1G8SN-107:A-ND | MT41K1G8SN-107:A |
| MT41K512M16HA-107:A-ND | MT41K512M16HA-107:A |
| MT41K2G4SN-125:A-ND | MT41K2G4SN-125:A |
| MT41K512M16HA-125IT:A-ND | MT41K512M16HA-125 IT:A |
| MT41K1G8SN-107IT:A-ND | MT41K1G8SN-107 IT:A |
| MT41K512M16TNA-107:E-ND | MT41K512M16TNA-107:E |
| 557-1763-ND | MT41K512M8DA-107 XIT:P |
| MT41K256M16HA-125V:E-ND | MT41K256M16HA-125 V:E |
| MT41K512M8RH-125V:E-ND | MT41K512M8RH-125 V:E |
| MT41K256M16V80AWC1-ND | MT41K256M16V80AWC1 |
| MT41K512M8V80AWC1-ND | MT41K512M8V80AWC1 |
| MT41K256M16HA-125AAT:E-ND | MT41K256M16HA-125 AAT:E |
| MT41K512M8RH-125MAIT:ETR-ND | MT41K512M8RH-125 M AIT:E TR |
| MT41K512M8RH-125MAIT:E-ND | MT41K512M8RH-125 M AIT:E |
| MT41K256M16HA-125V:ETR-ND | MT41K256M16HA-125 V:E TR |
| MT41K512M8RH-125V:ETR-ND | MT41K512M8RH-125 V:E TR |
| MT41K256M16HA-125XIT:ETR-ND | MT41K256M16HA-125 XIT:E TR |
| MT41K512M8RH-125XIT:ETR-ND | MT41K512M8RH-125 XIT:E TR |
| MT41K256M16HA-125AAT:ETR-ND | MT41K256M16HA-125 AAT:E TR |
| MT41K512M8RH-125AAT:ETR-ND | MT41K512M8RH-125 AAT:E TR |
| MT41K128M16JT-125V:KTR-ND | MT41K128M16JT-125 V:K TR |
| 557-1740-2-ND | MT41K1G16DGA-125:A TR |
| MT41K1G8SN-125IT:ATR-ND | MT41K1G8SN-125 IT:A TR |
| MT41K256M16LY-093:NTR-ND | MT41K256M16LY-093:N TR |
| MT41K256M16TW-093IT:PTR-ND | MT41K256M16TW-093 IT:P TR |
| MT41K2G4RKB-107:NTR-ND | MT41K2G4RKB-107:N TR |
| MT41K512M16HA-107IT:ATR-ND | MT41K512M16HA-107 IT:A TR |
| MT41K512M16HA-125AIT:ATR-ND | MT41K512M16HA-125 AIT:A TR |
| MT41K512M8DA-093IT:PTR-ND | MT41K512M8DA-093 IT:P TR |
| MT41K64M16TW-125:JTR-ND | MT41K64M16TW-125:J TR |
| MT41K2G8KJR-125:ATR-ND | MT41K2G8KJR-125:A TR |
| MT41K2G8KJR-125:A-ND | MT41K2G8KJR-125:A |
| MT41K2G4SN-125:ATR-ND | MT41K2G4SN-125:A TR |
| MT41K128M8DA-107AIT:J-ND | MT41K128M8DA-107 AIT:J |
| MT41K1G16DGA-125:A-ND | MT41K1G16DGA-125:A |
| MT41K256M8DA-107IT:K-ND | MT41K256M8DA-107 IT:K |
| MT41K256M16TW-107V:P-ND | MT41K256M16TW-107 V:P |
| MT41K256M8DA-107AIT:K-ND | MT41K256M8DA-107 AIT:K |
| MT41K512M8DA-125:P-ND | MT41K512M8DA-125:P |
| MT41K1G4RG-107:N-ND | MT41K1G4RG-107:N |
| MT41K256M8DA-125AUT:K-ND | MT41K256M8DA-125 AUT:K |
| MT41K256M16TW-107V:PTR-ND | MT41K256M16TW-107 V:P TR |
| MT41K256M8DA-107AIT:KTR-ND | MT41K256M8DA-107 AIT:K TR |
| MT41K256M8DA-107IT:KTR-ND | MT41K256M8DA-107 IT:K TR |
| MT41K256M8DA-125AUT:KTR-ND | MT41K256M8DA-125 AUT:K TR |
| MT41K512M8DA-125:PTR-ND | MT41K512M8DA-125:P TR |
| MT41K256M16TW-125:P-ND | MT41K256M16TW-125:P |
| MT41K512M16HA-107G:A-ND | MT41K512M16HA-107G:A |
| MT41K64M16TW-125:J-ND | MT41K64M16TW-125:J |
| MT41K64M16V88AWC1-ND | MT41K64M16V88AWC1 |
| MT41K128M16JT-125V:K-ND | MT41K128M16JT-125 V:K |
| MT41K256M16TW-093IT:P-ND | MT41K256M16TW-093 IT:P |
| MT41K512M8DA-093IT:P-ND | MT41K512M8DA-093 IT:P |
| MT41K512M16HA-107IT:A-ND | MT41K512M16HA-107 IT:A |
| MT41K1G8RKB-107:N-ND | MT41K1G8RKB-107:N |
| MT41K1G8SN-125IT:A-ND | MT41K1G8SN-125 IT:A |
| MT41K256M16LY-107:N-ND | MT41K256M16LY-107:N |
| MT41K2G4RKB-107:N-ND | MT41K2G4RKB-107:N |
| MT41K512M16HA-125AIT:A-ND | MT41K512M16HA-125 AIT:A |
| MT41K512M8RG-093:N-ND | MT41K512M8RG-093:N |
| MT41K512M8RG-107:N-ND | MT41K512M8RG-107:N |
| MT41K512M16V91AWC1-ND | MT41K512M16V91AWC1 |
