Mini USB Type B 5-Pin Right angle connector for Blue yeti microphone
Hi
Is this product suitable to replace a Blue yeti mini USB B female connector: Molex 0548190589
It looks very similar to this: https://youtu.be/Y2sNQonIPSs?si=zQnJxLifzTdvTwcX&t=299
Welcome to the Technical Forum. It is a Mini USB female connector. The only way you can verify if this will work is to actually do measurements. There is no easy way to do this other than the compare using the Molex data sheet and the part you have in your hand.
Hi g11,
Based on that video, I’d say no to the Molex 0548190589. It has surface mount contact pins, as seen in the diagram below. In the video, it shows through-hole contacts.
Figure 1: Molex 0548190589 (note surface mount contacts)
Figure 2: From above-referenced Blue Yeti microphone repair video
The only currently in-stock part I have found which appears to have the same footprint with four stabilizing mounting posts and through-hole pins is the now-obsolete Omron XM7D-0512.
Figure 3: Omron XM7D-0512 image
Figure 4: Omron XM7D-0512 diagram and footprint
