This document describes the third learning module for the Industrial Automation Technician.
Pathway Status: This module index is under active development. Available lessons are linked below; additional lessons and assessments will be added as they are completed.
This article is part of the DigiKey Structured Learning Pathways.
Last updated: 24 Jul 2026
Timing Relays
- What Is a Multifunction Relay?
- How to Add a Timer Module to Turn a Standard Relay into a Time-Delay Relay
- Construct a TOFF Delay Using a TON Delay Relay
