The Molex-1052620002 should be 868MHZ/915MHZ as per the datasheet.
However, the description on DigiKey says 866MHZ/915MHZ.
Which is correct?
Thank you,
Which is correct?
Thank you,
Thank you for your inquiry and welcome to the community.
The datasheet lists the frequency range of 1052620002 as being between 863Mhz - 870Mhz
The center frequency of those two frequencies is 866.5Mhz.
866Mhz would be closer to correct.
Hello Kristof,
Thank you for your prompt reply.
On other websites, i’ve found the same product but the description details is different:
"Antennas ISM 868/915 MHz ANTENNA 150MM"
I would like to confirm that the one on DigiKey is the same.
Thank you,
Confirmed. They are the same.
Noted! Thank you for your support.
