I came across a specific Permanent Mount and I’m having difficulty finding it once more and hoping someone can help.
The mount/bracket was directly under the antenna, covering the connector as well as the wire and would have a mounting pole/rod inserted into it at the bottom, with the antenna atop it. I believe it was in two pieces that where screwed together.
A lot of the mounting brackets I’ve found since don’t cover the connector and allow me to run the wire down the pole.
Any help is greatly appreciated.
