The data sheets on part number MT2000-6.0-X-SP from TE Connectivity do not address the length of the product nor which system of measurement should be used.
| MFR PART # | MT2000-6.0-6-SP |
| DIGIKEY PART # | 484-MT2000-6.0-6-SP-DS-ND |
| MANUFACTURER | TE Connectivity Raychem Cable Protection |
| DESCRIPTION | Heat Shrink Tubing, Semi Rigid 0.236" (5.99mm) 2.5 to 1 Blue Enter Number of Feet in Order Quantity |
After communicating with TE we were made to understand the minimum order (as of this writing) is 6250ft. One spool is 1250ft. MOQ is 6250ft, or 5 spools in length.
