There’s occasionally some confusion on the length per unit and spool length for the Thermofit RNF-3000 series from TE Connectivity Raychem Cable Protection. Most entries are clearly marked with a length spec, but for part numbers with a blank length spec, or for part numbers that are listed with a large order minimum on our site it can become confusing.
Simply put, unless it is the -STK suffix which is 4-foot long per stick, this series is measured by the meter, with the standard spool being 300 meters long. Any part number with an order minimum on our site for the RNF-3000 is going to be in meters.
Part Numbers Affected
RNF-3000-12/4-X-SP-150-ND
RNF-3000-3/1-X-SP-300-ND
2266-RNF-3000-9/3-0-SP-ND,RNF-3000-9/3-0-SP-150-ND
RNF-3000-9/3-X-SP-150-ND
RNF-3000-6/2-2-SP-ND
484-RNF-3000-39/13-X-SP-DS-ND
484-RNF-3000-24/8-2-SP-DS-ND
RNF-3000-39/13-5-SP-ND
RNF-3000-39/13-7-SP-ND
RNF-3000-39/13-3-SP-ND
484-RNF-3000-24/8-4-SP-DS-ND
484-RNF-3000-24/8-X-SP-DS-ND
RNF-3000-39/13-9-SP-ND
RNF-3000-39/13-4-SP-ND
RNF-3000-39/13-2-SP-ND
RNF-3000-39/13-6-SP-60-ND
484-RNF-3000-18/6-X-SP-DS-ND
RNF-3000-39/13-0-SP-60-ND
RNF-3000-24/8-3-SP-ND
RNF-3000-24/8-8-SP-ND
484-RNF-3000-12/4-2-SP-DS-ND
484-RNF-3000-12/4-X-SP-DS-ND
2266-RNF-3000-18/6-0-SP-ND,484-RNF-3000-18/6-0-SP-DS-ND
484-RNF-3000-12/4-0-SP-DS-ND
RNF-3000-24/8-5-SP-60-ND
484-RNF-3000-9/3-X-SP-DS-ND
2266-RNF-3000-9/3-8-SPTR-ND,A119823-150-ND
484-RNF-3000-9/3-0-SP-DS-ND
484-RNF-3000-6/2-9-SP-DS-ND
RNF-3000-18/6-5-SP-ND
A119820-150-ND
RNF-3000-18/6-1-SP-ND
484-RNF-3000-6/2-X-SP-DS-ND
484-RNF-3000-6/2-2-SP-DS-ND
484-RNF-3000-6/2-0-SP-DS-ND
RNF-3000-24/8-6-SP-ND
RNF-3000-24/8-9-SP-ND
RNF-3000-24/8-0-SP-60-ND
RNF-3000-18/6-7-SP-ND
RNF-3000-18/6-3-SP-ND
RNF-3000-12/4-1-SP-ND
RNF-3000-12/4-3-SP-ND
RNF-3000-12/4-5-SP-ND
484-RNF-3000-1.5/0.5-2-SP-DS-ND
A119819-150-ND
484-RNF-3000-1.5/0.5-X-SP-DS-ND
RNF-3000-18/6-0-FSP-ND
484-RNF-3000-3/1-X-SP-DS-ND
484-RNF-3000-3/1-0-SP-DS-ND
RNF-3000-9/3-1-SP-ND
2266-RNF-3000-6/2-8-SPTR-ND,A119822-150-ND
RNF-3000-18/6-4-SP-ND
RNF-3000-18/6-2-SP-150-ND
RNF-3000-18/6-6-SP-150-ND
RNF-3000-18/6-9-SP-ND
2266-RNF-3000-9/3-4-SP-ND,RNF-3000-9/3-4-SP-150-ND
RNF-3000-12/4-9-SP-150-ND
RNF-3000-12/4-6-SP-ND
RNF-3000-12/4-4-SP-ND
RNF-3000-6/2-5-SP-ND
484-RNF-3000-6/2-4-SP-DS-ND
2266-9755984004-484-ND,RNF-3000-3/1-5-SP-ND
RNF-3000-6/2-3-SP-ND
RNF-3000-9/3-2-SP-150-ND
RNF-3000-9/3-6-SP-ND
A109329-150-ND
A119818-300-ND
RNF-3000-6/2-X-SP-150-ND
RNF-3000-6/2-9-SP-150-ND
RNF-3000-3/1-8-SP-ND
RNF-3000-3/1-1-SP-ND
RNF-3000-3/1-7-SP-300-ND
A119817-600-ND
RNF-3000-1.5/0.5-1-SP-ND
A119821-150-ND
RNF-3000-3/1-3-SP-ND
A109028-300-ND
A109029-300-ND
RNF-3000-4.5/1.5-X-SP-ND
RNF-3000-1.5/0.5-X-SP-300-ND
484-5677764001-ND
RNF-3000-1.5/0.5-9-SP-ND
RNF-3000-1.5/0.5-4-SP-ND
RNF-3000-1.5/0.5-0-SP-600-ND
RNF-3000-3/1-2-SP-ND
RNF-3000-3/1-4-SP-300-ND
RNF-3000-3/1-6-SP-ND
RNF-3000-3/1-9-SP-ND
RNF-3000-NR508-X-SP-ND
