Need exact dimension for ALAN-101-T for this transformer
Hi all ,
I am looking exact physical dimension for ALAN-101-T for transformer. i could see there is dimension in DigiKey (11.43mm x 6.73mm) but in datasheet dimension is 12.8mmx6.73. which one i need to follow. I downloaded the 3D Model for this. it is showing 11.43x6.73mm. so which one i need to follow ? i need quick response asap
Thank you for pointing this out.
The correct dimensions will be on the data sheet. Should be 12.80mm x 6.90mm.
I will get this summited and corrected on our web site.
