I have inquired about molex PCB connector. But I only have image. Can you help me to check
Welcome to the Digikey tech forum. Take a look at Digikey part 900-2202500069CT-ND as a possible option. The drawing can be found here to verify dimensions.
Yes, you are correct. I wasn’t able to find an exact cross. You will need to use the drawing to measure and verify if this will work for you.
