hello i need help identifying the attached picture of a smd, Ive spend a couple hours trying to track down a datasheet to try to figure out what this is i hope someone can help me track something down
the numbers on the component are as follows ST E
MR
c725
Hello 725, You have SM6T30CA not stocking but take a look at 497-10800-1-ND stocking change is it is automotive grade. Thank you 725.
Robert_1552 it is used on a pcb board from an industrial machine
hello and thanks for you help much appreciated
