Hello!
I have two relays that I need new modern equivalents for. Thank you.
Hello @dennisfrancis
The only 2 VDC relay I found on our site is part number 9-1415389-1 TE Connectivity Potter & Brumfield Relays | Relays | DigiKey, But I do not think this will work in place of the RABK-2P due to its size.
for the MAT2B relay I was not able to find more information about it and the link below is all the 12VDC, DPST-NO contacts we have. You can narrow down the list if you know what the amperage of the relay is, and like I said I was not able to find any information on that relay.
12VDC Power Relays, Over 2 Amps | Electronic Components Distributor DigiKey
Markings look a bit worn–likely a 12V relay considering the rarity of 2V units and the oddity of mixing voltages like that on a board so old.
Markings on that unit indicate a DPDT unit, but I’m not finding information re. ratings that would indicate whether one’s looking at a signal or power relay.
In either case, much of the battle in PC-mount relay replacement is finding something with a compatible footprint.
Thanks gents!
