I want to know if the X-Ray Bonding position of this Part number is not the same, will it affect its efficacy? Or is this normal?
D/C 2424 & 2425 COO CN
Welcome to the DigiKey TechForum. Please send your information including the DigiKey sales order number for these parts to applications.engineering@digikey.com for assistance, thanks.
Where did you buy units, can you share the date codes?
This would depend on the die, you should etch the coating to see the metal connection layers.
I’m betting there was a change in the die or a produced from a different fab.
Make sure to check for a die revision…
Regards,
Date Code 2424 & 2425 COO CN
because we connot found any PCN for die..Can I know if you can help with this concern?
Thanks for the information, please send your information including the DigiKey sales order number for these parts to applications.engineering@digikey.com for assistance.
