We have received questions recently on how many terminals are on K16 series switches from Kacon. For example take the K16-291-G-24VDC(2371-K16-291-G-24VDC-ND), on our product detail page it lists the termination as: Solder, Quick Connect - 0.110" (2.8mm) but it doesn’t say how many and neither does the datasheet. The answer is it depends upon your specific switch model.
To find this information we have to consult the catalog on the manufacturer’s website.
To determine the number of terminals we need two pieces of information, the contact form and whether or not the switch is illuminated.
Let’s take a look at our example part number above, K16-291-G-24VDC. Using the part number breakdown on page 2 of the catalog we can see our part has contact form 1C and it is illuminated (seen below).
Once we have that information we proceed to the wiring diagram on page 16 and we can see that there are five terminations on our switch (seen below).
Wiring diagram zoomed in on Illuminated 1C:
Applicable Part Numbers
| 2371-K16-212-G-ND | K16-212-G |
| 2371-K16-212-R-ND | K16-212-R |
| 2371-K16-311-B-ND | K16-311-B |
| 2371-K16-271-G-6VDC-ND | K16-271-G-6VDC |
| 2371-K16-271-G-24VDC-ND | K16-271-G-24VDC |
| 2371-K16-312-R-ND | K16-312-R |
| 2371-K16-381-W-12VDC-ND | K16-381-W-12VDC |
| 2371-K16-371-R-24VDC-ND | K16-371-R-24VDC |
| 2371-K16-282-W-24VDC-ND | K16-282-W-24VDC |
| 2371-K16-382-B-24VDC-ND | K16-382-B-24VDC |
| 2371-K16-372-Y-12VDC-ND | K16-372-Y-12VDC |
| 2371-K16-311-G-ND | K16-311-G |
| 2371-K16-372-B-12VDC-ND | K16-372-B-12VDC |
| 2371-K16-211-G-ND | K16-211-G |
| 2371-K16-221-G-ND | K16-221-G |
| 2371-K16-211-Y-ND | K16-211-Y |
| 2371-K16-231-R-ND | K16-231-R |
| 2371-K16-222-R-ND | K16-222-R |
| 2371-K16-311-R-ND | K16-311-R |
| 2371-K16-232-W-ND | K16-232-W |
| 2371-K16-281-W-24VDC-ND | K16-281-W-24VDC |
| 2371-K16-271-W-24VDC-ND | K16-271-W-24VDC |
| 2371-K16-281-R-12VDC-ND | K16-281-R-12VDC |
| 2371-K16-281-W-12VDC-ND | K16-281-W-12VDC |
| 2371-K16-291-R-12VDC-ND | K16-291-R-12VDC |
| 2371-K16-291-W-12VDC-ND | K16-291-W-12VDC |
| 2371-K16-271-W-12VDC-ND | K16-271-W-12VDC |
| 2371-K16-271-Y-24VDC-ND | K16-271-Y-24VDC |
| 2371-K16-291-B-12VDC-ND | K16-291-B-12VDC |
| 2371-K16-271-Y-12VDC-ND | K16-271-Y-12VDC |
| 2371-K16-281-Y-12VDC-ND | K16-281-Y-12VDC |
| 2371-K16-271-R-24VDC-ND | K16-271-R-24VDC |
| 2371-K16-281-G-24VDC-ND | K16-281-G-24VDC |
| 2371-K16-281-Y-24VDC-ND | K16-281-Y-24VDC |
| 2371-K16-271-W-6VDC-ND | K16-271-W-6VDC |
| 2371-K16-291-G-24VDC-ND | K16-291-G-24VDC |
| 2371-K16-281-R-24VDC-ND | K16-281-R-24VDC |
| 2371-K16-281-G-12VDC-ND | K16-281-G-12VDC |
| 2371-K16-281-B-24VDC-ND | K16-281-B-24VDC |
| 2371-K16-291-G-12VDC-ND | K16-291-G-12VDC |
| 2371-K16-281-Y-6VDC-ND | K16-281-Y-6VDC |
| 2371-K16-271-B-24VDC-ND | K16-271-B-24VDC |
| 2371-K16-271-B-12VDC-ND | K16-271-B-12VDC |
| 2371-K16-291-B-6VDC-ND | K16-291-B-6VDC |
| 2371-K16-291-G-6VDC-ND | K16-291-G-6VDC |
| 2371-K16-291-Y-12VDC-ND | K16-291-Y-12VDC |
| 2371-K16-291-Y-24VDC-ND | K16-291-Y-24VDC |
| 2371-K16-271-R-12VDC-ND | K16-271-R-12VDC |
| 2371-K16-281-R-6VDC-ND | K16-281-R-6VDC |
| 2371-K16-291-R-6VDC-ND | K16-291-R-6VDC |
| 2371-K16-291-W-24VDC-ND | K16-291-W-24VDC |
| 2371-K16-281-W-6VDC-ND | K16-281-W-6VDC |
| 2371-K16-291-R-24VDC-ND | K16-291-R-24VDC |
| 2371-K16-312-G-ND | K16-312-G |
| 2371-K16-391-W-24VDC-ND | K16-391-W-24VDC |
| 2371-K16-391-W-12VDC-ND | K16-391-W-12VDC |
| 2371-K16-272-B-12VDC-ND | K16-272-B-12VDC |
| 2371-K16-282-B-24VDC-ND | K16-282-B-24VDC |
| 2371-K16-371-Y-24VDC-ND | K16-371-Y-24VDC |
| 2371-K16-292-R-24VDC-ND | K16-292-R-24VDC |
| 2371-K16-371-G-24VDC-ND | K16-371-G-24VDC |
| 2371-K16-381-B-24VDC-ND | K16-381-B-24VDC |
| 2371-K16-381-G-12VDC-ND | K16-381-G-12VDC |
| 2371-K16-381-R-12VDC-ND | K16-381-R-12VDC |
| 2371-K16-292-G-24VDC-ND | K16-292-G-24VDC |
| 2371-K16-381-B-12VDC-ND | K16-381-B-12VDC |
| 2371-K16-272-Y-24VDC-ND | K16-272-Y-24VDC |
| 2371-K16-272-R-24VDC-ND | K16-272-R-24VDC |
| 2371-K16-391-Y-12VDC-ND | K16-391-Y-12VDC |
| 2371-K16-381-W-24VDC-ND | K16-381-W-24VDC |
| 2371-K16-391-B-12VDC-ND | K16-391-B-12VDC |
| 2371-K16-272-W-6VDC-ND | K16-272-W-6VDC |
| 2371-K16-292-B-12VDC-ND | K16-292-B-12VDC |
| 2371-K16-272-G-6VDC-ND | K16-272-G-6VDC |
| 2371-K16-272-W-12VDC-ND | K16-272-W-12VDC |
| 2371-K16-282-G-12VDC-ND | K16-282-G-12VDC |
| 2371-K16-272-G-12VDC-ND | K16-272-G-12VDC |
| 2371-K16-282-G-24VDC-ND | K16-282-G-24VDC |
| 2371-K16-282-G-6VDC-ND | K16-282-G-6VDC |
| 2371-K16-381-G-24VDC-ND | K16-381-G-24VDC |
| 2371-K16-391-R-6VDC-ND | K16-391-R-6VDC |
| 2371-K16-282-Y-12VDC-ND | K16-282-Y-12VDC |
| 2371-K16-282-R-24VDC-ND | K16-282-R-24VDC |
| 2371-K16-371-G-12VDC-ND | K16-371-G-12VDC |
| 2371-K16-272-R-12VDC-ND | K16-272-R-12VDC |
| 2371-K16-371-B-24VDC-ND | K16-371-B-24VDC |
| 2371-K16-282-Y-24VDC-ND | K16-282-Y-24VDC |
| 2371-K16-292-Y-12VDC-ND | K16-292-Y-12VDC |
| 2371-K16-391-B-24VDC-ND | K16-391-B-24VDC |
| 2371-K16-381-Y-24VDC-ND | K16-381-Y-24VDC |
| 2371-K16-292-R-12VDC-ND | K16-292-R-12VDC |
| 2371-K16-272-W-24VDC-ND | K16-272-W-24VDC |
| 2371-K16-381-R-24VDC-ND | K16-381-R-24VDC |
| 2371-K16-272-B-24VDC-ND | K16-272-B-24VDC |
| 2371-K16-382-B-12VDC-ND | K16-382-B-12VDC |
| 2371-K16-392-Y-12VDC-ND | K16-392-Y-12VDC |
| 2371-K16-372-G-24VDC-ND | K16-372-G-24VDC |
| 2371-K16-372-Y-24VDC-ND | K16-372-Y-24VDC |
| 2371-K16-392-G-24VDC-ND | K16-392-G-24VDC |
| 2371-K16-372-R-24VDC-ND | K16-372-R-24VDC |
| 2371-K16-382-W-12VDC-ND | K16-382-W-12VDC |
| 2371-K16-392-R-12VDC-ND | K16-392-R-12VDC |
| 2371-K16-382-Y-24VDC-ND | K16-382-Y-24VDC |
| 2371-K16-392-B-24VDC-ND | K16-392-B-24VDC |
| 2371-K16-382-W-24VDC-ND | K16-382-W-24VDC |
| 2371-K16-382-G-12VDC-ND | K16-382-G-12VDC |
| 2371-K16-331-W-ND | K16-331-W |
| 2371-K16-271-B-6VDC-ND | K16-271-B-6VDC |
| 2371-K16-281-B-12VDC-ND | K16-281-B-12VDC |
| 2371-K16-281-B-6VDC-ND | K16-281-B-6VDC |
| 2371-K16-271-Y-6VDC-ND | K16-271-Y-6VDC |
| 2371-K16-291-Y-6VDC-ND | K16-291-Y-6VDC |
| 2371-K16-322-R-ND | K16-322-R |
| 2371-K16-322-Y-ND | K16-322-Y |
| 2371-K16-322-G-ND | K16-322-G |
| 2371-K16-312-Y-ND | K16-312-Y |
| 2371-K16-312-B-ND | K16-312-B |
| 2371-K16-332-B-ND | K16-332-B |
| 2371-K16-322-B-ND | K16-322-B |
| 2371-K16-312-W-ND | K16-312-W |
| 2371-K16-332-Y-ND | K16-332-Y |
| 2371-K16-332-R-ND | K16-332-R |
| 2371-K16-322-W-ND | K16-322-W |
| 2371-K16-332-W-ND | K16-332-W |
| 2371-K16-332-G-ND | K16-332-G |
| 2371-K16-371-W-12VDC-ND | K16-371-W-12VDC |
| 2371-K16-371-Y-12VDC-ND | K16-371-Y-12VDC |
| 2371-K16-371-B-12VDC-ND | K16-371-B-12VDC |
| 2371-K16-292-Y-24VDC-ND | K16-292-Y-24VDC |
| 2371-K16-371-W-24VDC-ND | K16-371-W-24VDC |
| 2371-K16-391-Y-6VDC-ND | K16-391-Y-6VDC |
| 2371-K16-371-R-6VDC-ND | K16-371-R-6VDC |
| 2371-K16-391-R-24VDC-ND | K16-391-R-24VDC |
| 2371-K16-371-R-12VDC-ND | K16-371-R-12VDC |
| 2371-K16-292-R-6VDC-ND | K16-292-R-6VDC |
| 2371-K16-282-R-12VDC-ND | K16-282-R-12VDC |
| 2371-K16-292-G-6VDC-ND | K16-292-G-6VDC |
| 2371-K16-282-B-6VDC-ND | K16-282-B-6VDC |
| 2371-K16-371-Y-6VDC-ND | K16-371-Y-6VDC |
| 2371-K16-391-Y-24VDC-ND | K16-391-Y-24VDC |
| 2371-K16-391-W-6VDC-ND | K16-391-W-6VDC |
| 2371-K16-292-W-12VDC-ND | K16-292-W-12VDC |
| 2371-K16-381-B-6VDC-ND | K16-381-B-6VDC |
| 2371-K16-282-Y-6VDC-ND | K16-282-Y-6VDC |
| 2371-K16-381-W-6VDC-ND | K16-381-W-6VDC |
| 2371-K16-381-R-6VDC-ND | K16-381-R-6VDC |
| 2371-K16-371-G-6VDC-ND | K16-371-G-6VDC |
| 2371-K16-272-Y-12VDC-ND | K16-272-Y-12VDC |
| 2371-K16-292-W-24VDC-ND | K16-292-W-24VDC |
| 2371-K16-292-W-6VDC-ND | K16-292-W-6VDC |
| 2371-K16-282-R-6VDC-ND | K16-282-R-6VDC |
| 2371-K16-371-B-6VDC-ND | K16-371-B-6VDC |
| 2371-K16-371-W-6VDC-ND | K16-371-W-6VDC |
| 2371-K16-282-B-12VDC-ND | K16-282-B-12VDC |
| 2371-K16-392-R-24VDC-ND | K16-392-R-24VDC |
| 2371-K16-382-Y-12VDC-ND | K16-382-Y-12VDC |
| 2371-K16-382-R-12VDC-ND | K16-382-R-12VDC |
| 2371-K16-382-G-24VDC-ND | K16-382-G-24VDC |
| 2371-K16-392-B-12VDC-ND | K16-392-B-12VDC |
| 2371-K16-382-R-6VDC-ND | K16-382-R-6VDC |
| 2371-K16-382-Y-6VDC-ND | K16-382-Y-6VDC |
| 2371-K16-372-B-6VDC-ND | K16-372-B-6VDC |
| 2371-K16-392-B-6VDC-ND | K16-392-B-6VDC |
| 2371-K16-392-G-12VDC-ND | K16-392-G-12VDC |
| 2371-K16-382-R-24VDC-ND | K16-382-R-24VDC |
| 2371-K16-392-Y-6VDC-ND | K16-392-Y-6VDC |
| 2371-K16-392-Y-24VDC-ND | K16-392-Y-24VDC |
| 2371-K16-392-W-12VDC-ND | K16-392-W-12VDC |
| 2371-K16-372-G-12VDC-ND | K16-372-G-12VDC |
| 2371-K16-392-W-24VDC-ND | K16-392-W-24VDC |
| 2371-K16-382-B-6VDC-ND | K16-382-B-6VDC |
| 2371-K16-372-R-6VDC-ND | K16-372-R-6VDC |
| 2371-K16-372-Y-6VDC-ND | K16-372-Y-6VDC |
| 2371-K16-372-W-24VDC-ND | K16-372-W-24VDC |
| 2371-K16-372-B-24VDC-ND | K16-372-B-24VDC |
| 2371-K16-392-W-6VDC-ND | K16-392-W-6VDC |
| 2371-K16-382-G-6VDC-ND | K16-382-G-6VDC |
| 2371-K16-211-R-ND | K16-211-R |
| 2371-K16-231-W-ND | K16-231-W |
| 2371-K16-221-B-ND | K16-221-B |
| 2371-K16-331-B-ND | K16-331-B |
| 2371-K16-232-G-ND | K16-232-G |
| 2371-K16-232-B-ND | K16-232-B |
| 2371-K16-232-R-ND | K16-232-R |
| 2371-K16-321-G-ND | K16-321-G |
| 2371-K16-212-Y-ND | K16-212-Y |
| 2371-K16-212-W-ND | K16-212-W |
| 2371-K16-271-G-12VDC-ND | K16-271-G-12VDC |
| 2371-K16-281-G-6VDC-ND | K16-281-G-6VDC |
| 2371-K16-271-R-6VDC-ND | K16-271-R-6VDC |
| 2371-K16-292-G-12VDC-ND | K16-292-G-12VDC |
| 2371-K16-282-W-12VDC-ND | K16-282-W-12VDC |
| 2371-K16-391-R-12VDC-ND | K16-391-R-12VDC |
| 2371-K16-372-R-12VDC-ND | K16-372-R-12VDC |
| 2371-K16-291-B-24VDC-ND | K16-291-B-24VDC |
| 2371-K16-391-G-12VDC-ND | K16-391-G-12VDC |
| 2371-K16-391-G-24VDC-ND | K16-391-G-24VDC |
| 2371-K16-272-G-24VDC-ND | K16-272-G-24VDC |
| 2371-K16-221-W-ND | K16-221-W |
| 2371-K16-221-Y-ND | K16-221-Y |
| 2371-K16-221-R-ND | K16-221-R |
| 2371-K16-231-Y-ND | K16-231-Y |
| 2371-K16-231-G-ND | K16-231-G |
| 2371-K16-211-B-ND | K16-211-B |
| 2371-K16-211-W-ND | K16-211-W |
| 2371-K16-231-B-ND | K16-231-B |
| 2371-K16-222-Y-ND | K16-222-Y |
| 2371-K16-321-Y-ND | K16-321-Y |
| 2371-K16-321-R-ND | K16-321-R |
| 2371-K16-311-Y-ND | K16-311-Y |
| 2371-K16-321-B-ND | K16-321-B |
| 2371-K16-311-W-ND | K16-311-W |
| 2371-K16-331-Y-ND | K16-331-Y |
| 2371-K16-321-W-ND | K16-321-W |
| 2371-K16-222-G-ND | K16-222-G |
| 2371-K16-331-G-ND | K16-331-G |
| 2371-K16-222-W-ND | K16-222-W |
| 2371-K16-232-Y-ND | K16-232-Y |
| 2371-K16-222-B-ND | K16-222-B |
| 2371-K16-212-B-ND | K16-212-B |
| 2371-K16-291-W-6VDC-ND | K16-291-W-6VDC |
| 2371-K16-292-Y-6VDC-ND | K16-292-Y-6VDC |
| 2371-K16-391-B-6VDC-ND | K16-391-B-6VDC |
| 2371-K16-292-B-6VDC-ND | K16-292-B-6VDC |
| 2371-K16-292-B-24VDC-ND | K16-292-B-24VDC |
| 2371-K16-272-Y-6VDC-ND | K16-272-Y-6VDC |
| 2371-K16-391-G-6VDC-ND | K16-391-G-6VDC |
| 2371-K16-272-R-6VDC-ND | K16-272-R-6VDC |
| 2371-K16-381-Y-12VDC-ND | K16-381-Y-12VDC |
| 2371-K16-372-W-6VDC-ND | K16-372-W-6VDC |
| 2371-K16-382-W-6VDC-ND | K16-382-W-6VDC |
| 2371-K16-372-G-6VDC-ND | K16-372-G-6VDC |
| 2371-K16-392-G-6VDC-ND | K16-392-G-6VDC |
| 2371-K16-392-R-6VDC-ND | K16-392-R-6VDC |
| 2371-K16-372-W-12VDC-ND | K16-372-W-12VDC |
