On Semiconductor has an AEC/PPAP Automotive status check on their website.
https://www.onsemi.com/PowerSolutions/aec.do
You can also use this to show that On Semiconductor uses the suffix F085 to callout for Automotive Qualified. You can do this by searching the base number, without the F085 suffix, in the link above. Once searched it will provide you with both numbers in a table format showing only the F085 is Automotive Qualifed.
For Example:
