Hi
I want to change the 32.768KHz OSC for RTC from external to internal.
I referenced the content of site below.
[Custom OSD3358 SiP] 4.19-RT-Kernel panic (shutdown)
I changed the file : 0001-am335x_evm-uEnv.txt-bootz-n-fixes.patch
+#if defined(CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSC)
void rtc32k_enable(void)
+ struct davinci_rtc *rtc = (struct davinci_rtc *)RTC_BASE;
+ * Unlock the RTC's registers. For more details please see the
+ * RTC_SS section of the TRM. In order to unlock we need to
+ * write these specific values (keys) in this order.
+ writel(RTC_KICK0R_WE, &rtc->kick0r);
+ writel(RTC_KICK1R_WE, &rtc->kick1r);
if (board_is_pb() || board_is_blue()) {
/* 6: EN_32KCLK */
/* 3: SEL_32KCLK_SRC 0: internal, 1: external */
writel((0 << 3) | (1 << 6), &rtc->osc);
} else {
/* Enable the RTC 32K OSC by setting bits 3 and 6. */
writel((1 << 3) | (1 << 6), &rtc->osc);
+#endif
Is it right?
and How can I configure the *.dts for the RTC change.
I am not good at kernel source.
Please, could you explain how to configure it for beaglebone black in detail
Regards.
Hi @taek8461,
Since you defined your board as “board_is_bblter” change this line:
if (board_is_pb() || board_is_blue() || board_is_bblter()) {
/* 6: EN_32KCLK */
} else {
For the kernel remove these 2 lines:
&rtc {
clocks = <&clk_32768_ck>, <&clk_24mhz_clkctrl AM3_CLK_24MHZ_CLKDIV32K_CLKCTRL 0>;
clock-names = "ext-clk", "int-clk";
To:
&rtc {
That’ll get you the correct rtc clock set by u-boot
https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/arch/arm/boot/dts/am335x-bone-common.dtsi#n397
Regards,
Hi
Thank you for your help
if (board_is_pb() || board_is_blue() || board_is bblter()) {
/* 6: EN_32KCLK */
} else {
+#endif
static inline int board_is_bblter(void)
return board_is_bone_lt() && !strncmp(board_ti_get_rev(), "LTER", 4);
and then, I run two command as below
patch -p1 < 0001-am335x_evm-uEnv.txt-bootz-n-fixes.patch
patch -p1 < 0002-U-Boot-BeagleBone-Cape-Manager.patch
The following is the message after two command line run
I think the message show me some problems.
Could you let me know what I did wrong and how to fix it?
The following is install2_uboot.sh file.
please, help me.
Regards
Hi @taek8461, you just can’t randomly change lines in a *.patch file… Keep the original 2 patches the way they were, and create a 3rd patch with your actual changes.
The u-boot directory is a git repo, so it’s very easy to do a git diff and get your changes.
Regards,
