OSD3358-SM-RED ethernet not working
Hi,
I follow this page to rebuild a custom system :
https://www.digikey.com/eewiki/display/linuxonarm/OSD3358-SM-RED
But the Ethernet does not work.
I also try to build a system with buildroot, using latest kernel (5.1.5) from mainline with u-boot configured to load the osd3358-bsm-refdesign.dtb.
Phy is correctly initialized, and RJ45 cable correctly detected, but it seem that mac send Tx frame but nether receive nothing.
As default image is working well, I suppose that there is a patch or specific configuration for this board, but impossible to find clear documentation on it.
Does someone as a way to rebuild a image from source for the OSD3358-SM-RED board with ethernet port working ?
Thanks
System info following :
git:/opt/scripts/:[38ce81fcdafad0892b6c485acd4e9a2245dfb07a]
eeprom:[A335BNLTBBNR*]
model:[TI_AM335x_BeagleBone_Black]
bootloader:[microSD-(push-button)]:[/dev/mmcblk0]:[U-Boot 2019.04-dirty]:[location: dd MBR]
kernel:[4.19.50-bone35]
pkg check: to individually upgrade run: [sudo apt install --only-upgrade ]
pkg:[bb-cape-overlays]:[4.4.20190215.0-0rcnee0~stretch+20190215]
WARNING:pkg:[bb-wl18xx-firmware]:[NOT_INSTALLED]
pkg:[kmod]:[23-2rcnee1~stretch+20171005]
WARNING:pkg:[librobotcontrol]:[NOT_INSTALLED]
pkg:[firmware-ti-connectivity]:[20180825+dfsg-1rcnee1~stretch+20181217]
groups:[debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal i2c netdev gpio pwm eqep bluetooth admin spi tisdk weston-launch xenomai cloud9ide]
cmdline:[console=ttyO0,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait]
dmesg | grep pinctrl-single
[ 0.471698] pinctrl-single 44e10800.pinmux: 142 pins, size 568
dmesg | grep gpio-of-helper
debian@arm:~$
Sadly my board is in the lab, so i can’t take a look at this till Monday.
Does the v4.19.x-ti branch work better?
Regards,
I found the solution :
By default the OSD3358-SM-RED board is detected by uboot as a BeagleBone Black and uboot load the /boot/dtbs/4.19.50-bone35/am335x-boneblack.dtb
I just should edit the uEnv.txt and add :
dtb=am335x-osd3358-sm-red.dtb :
I saw that the kernel generation use specific scripts to patch it and build it.
Could this be doing by buildroot ?
It will be very interesting.
Regards
Ah good catch, and looking at your 2nd post:
Your eeprom is wrong:
It should be:
Octavo Systems OSD3358-SM-RED:
   0: [aa 55 33 ee 41 33 33 35  42 4e 4c 54 4F 53 30 30 |.U3.A335BNLTOS00|]
I’ve just pushed that eeprom to repo:
You can get that file by:
cd /opt/scripts/
git pull
Next to udpate your eeprom, we need to GND the WP. (Short J1)…
osd3358-eeprom
sudo dd if=/opt/scripts/device/bone/osd3358-sm-red-eeprom.dump of=/sys/devices/platform/ocp/44e0b000.i2c/i2c-0/0-0050/eeprom
Regards,
You are right. Thanks for the instruction.
Why the OSD3358-SM-RED eeprom could not be correctly written in production ? This is all the time or a mistake on my production batch ?
I followed your instruction, but first i had to add the eeprom in device tree.
eeprom declaration seem to be mising on some board :
grep -i -n -r "eeprom" am335x-*.dts
am335x-base0033.dts:91:	eeprom: eeprom@50 {
am335x-boneblue.dts:558:	baseboard_eeprom: baseboard_eeprom@50 {
am335x-cm-t335.dts:353:	/* CM-T335 board EEPROM */
am335x-cm-t335.dts:354:	eeprom: 24c02@50 {
am335x-moxa-uc-8100-me-t.dts:270:	eeprom: eeprom@50 {
am335x-nano.dts:226:	eeprom@53 {
am335x-pdu001.dts:292:	m2_eeprom: m2_eeprom@50 {
am335x-pepper.dts:69:	eeprom: eeprom@50 {
am335x-phycore-rdk.dts:16:&i2c_eeprom {
am335x-pocketbeagle.dts:996:	eeprom: eeprom@50 {
am335x-sl50.dts:468:	eeprom: eeprom@50 {
am335x-wega-rdk.dts:16:&i2c_eeprom {
Add eeprom in bb-kernel/KERNEL/arch/arm/boot/dts/am335x-osd3358-sm-red.dts :
&i2c0 {
	eeprom: eeprom@50 {
		compatible = "atmel,24c256";
		reg = <0x50>;
	tda19988: hdmi-encoder@70 {
Rebuild the linux kernel :
cd bb-kernel/
Edit the build_kernel.sh to unset FULL_REBUILD var
unset FULL_REBUILD
#FULL_REBUILD=1
Then
./build_kernel.sh
Copy the updated dtb to uSD :
cp bb-kernel/KERNEL/arch/arm/boot/dts/am335x-osd3358-sm-red.dtb /media/${DISK}/rootfs/boot/dtbs/4.19.50-bone35/
Boot the board.
Follow the RobertCNelson
Now the board is correctly detected by uboot :
Board: BeagleBone Black
Model: Octavo Systems OSD3358-SM-RED
