P121366-ND End of Life, replacement part?
P121366-ND (MFG EYG-T3535A15A) is reaching end of life. Is there a good replacement I can use?
Not seeing a suitable alternative.
Best I can advise is we have the alternate thicknesses of the same stuff in 2mm, 2.5mm and 3mm currently available if that will work in a pinch. < Click Here for Options >
Thank you! I appreciate the help. I’ll start there.
Looks like those are last time buys too.
I would have to agree with Kristof. At this time we do not have much to offer. I hoped we would get some product in to replace this , but so far not much yet. So keep checking. Right now this is the best we have to offer.
According to the EOL notification from Panasonic, they suggest the Graphite-TIM series as a replacement. If you cannot find one of those that will work, then it also says to contact Panasonic directly for an alternative solution.
Thank you all again. I’ll try starting with that and see if it works for our design.
Websites like Digi-Key, Mouser, and Octopart provide comprehensive databases of electronic components. You can search for the part number of the component you need to replace and find alternatives based on various parameters.
