Packaging as a Service (PaaS)
There’s just one difference between the MPN 0878321016 / WM23628-ND as CONN HEADER SMD 10POS 2mm and 0878321014 / WM14376xy -ND as Connector Header Surface Mount 10 position 0,079’’ (2,00mm) where our system is showing both are substitute for each other of the same series: Milli-Grid 87832 with the same 087832 Base Product Number from Molex.
Only the Packaging as a Service (PaaS) option xy is different for
CT – Cut Tape, DKR – Digi-Reel® and TR – Tape and Reel vs tube .
