Panasonic CA Series Connectors
What connector mates with the Panasonic CA series form C relay? I’m specifically looking at part number: CA1-DC12V-N. I am guessing it is one of the following from TE Connectivity:
171898-1
174204-1
178022-1
178025-1
171897-1
I’ve checked the Panasonic data sheet for the relay and it only gives dimensions for the terminals and housing but does not specify any part numbers for the connector. Can anyone help?
BRube
Thank you for contacting Digi-Key , part numbers 171898-1 and 178022-1 may be possible options , I have sent an email to the manufacturer to confirm , the other ones use male contacts and will not work .
