Panasonic SP Series Sealing/Washable?
The question regarding if Panasonic SP Series is washable?
You may note the cleaning process located on pg of the datasheet 14
■ Cleaning • Although the environmentally sealed type relay ( plastic sealed type, etc. ) can be cleaned, avoid immersing the relay into cold liquid ( such as cleaning solvent ) immediately after soldering. Doing so may deteriorate the sealing performance. • Cleaning with the boiling method is recommended ( The temperature of cleaning liquid should be 40 ℃ or lower ). Avoid ultrasonic cleaning on relays. Use of ultrasonic cleaning may cause breaks in the coil or slight sticking of the contacts due to ultrasonic energy.
