Can relays be entirely cleaned after mounting on a PCB, and can ultrasonic cleaning be applied?
Question:
Block
Answer:
Entire cleaning can be applied to the plastic-sealed relay. If ultrasonic cleaning is required, you must select a model supporting ultrasonic cleaning.
Block
Explanation:
Refer to the table below to select a cleaning method and cleaning solution.
For more information, see Safety Precautions for All Relays: 6-10 Automatic Mounting of Relays for PCBs.
Block
Quick tips
If a PCB on which multiple relays are mounted is cleaned, a cleaning residue is likely to be generated. Always check for residue, as cleaning residue may cause corrosion and insulation degradation.
Block
Please visit the link below to see this product line on the Digi-Key website
Relays | Digi-Key Electronics
https://components.omron.com/us-en/faq/relays/FAQE10069
