Part No JX0B-3116NL
Specifications is Connector Type: RJ45 Jack (Female / Receptacle), Shielded with EMI FingersPort Configuration: 2x2 Stacked (4 total ports, 2 rows)Applications: 10/100/1000 Base-T, Power over Ethernet (PoE+)
The part JX0B-3116NL is not a part that we have in our system and does not appear to be an active part number from Pulse Electronics. It could be a custom variation of part JX0B-3051NL.
Thanks Steven,
Actually we need a Connector Type: RJ45 Jack (Female / Receptacle), Shielded with EMI FingersPort Configuration: 2x2 Stacked (4 total ports, 2 rows)Applications: 10/100/1000 Base-T, Power over Ethernet (PoE+)
Also find enclosed front back and side photo attached as a reference.
Can you suggest and help ?
Regards,
This is not a part that we have. The only similar option is 2496687-1 from TE, but the PCB footprint is a different layout.
