Terminal block 3001938 from Phoenix Contact has the following image attached to it.
There has been some confusion regarding the voltage capabilities of this device as it is marked with +24V on the side. However, if we look at the product attributes section on the DigiKey website we can see the following ratings
Terminal Block Connector 2 Position Disconnect Black 8-26 AWG
| TYPE |
Ratings |
| Current - IEC |
30 A |
| Voltage - IEC |
250V |
| Current - UL |
30 A |
| Voltage - UL |
300V |
Link to data sheet
Answer:
The reason this product is marked with a +24 on the side is because of the internal LED used to identify the presence of voltage within it. There are a few different versions of these to accommodate different voltage levels.
If you do not have a 24V power source and use it in an application that utilizes a higher voltage, the part does still meet the ratings above but be aware, exceeding the voltage rating will burn out the LED.
If you do not need the LED indicator the recommended course of action is to use the part that does not have an LED in it. However, if that is not possible because of sourcing issues, you could possibly use one of these other options here.
More Phoenix Contact parts this applies to:
ST 4 FSI/C Series
ST 4-FSI/C - 3036372
| DigiKey Part Number |
277-2055-ND |
| Manufacturer |
Phoenix Contact |
| Manufacturer Product Number |
3036372 |
| LED |
No |
| LED Voltage |
None |
| Detailed Description |
Terminal Block Connector 2 Position Disconnect Black 10-28 AWG |
ST 4-FSI/C-LED 12 - 3036495
277-3912-ND |
| Manufacturer |
Phoenix Contact |
3036495 |
| LED |
Yes |
| LED Voltage |
12VDC |
ST 4-FSI/C-LED 24 - 3036505
277-3549-ND |
| Manufacturer |
Phoenix Contact |
3036505 |
| LED |
Yes |
| LED Voltage |
24VDC |
ST 4-FSI/C-LED 48 - 3035250
3035250-ND |
| Manufacturer |
Phoenix Contact |
3035250 |
| LED |
Yes |
| LED Voltage |
48VDC |
UK 6 FSI/C Series
UK 6-FSI/C - 3118203
277-3228-ND |
| Manufacturer |
Phoenix Contact |
3118203 |
| LED |
No |
| LED Voltage |
None |
Terminal Block Connector 2 Position Disconnect Black 8-26 AWG |
UK 6-FSI/C-LED12 - 3001925
277-3510-ND |
| Manufacturer |
Phoenix Contact |
3001925 |
| LED |
Yes |
| LED Voltage |
12VDC |
UK 6-FSI/C-LED24 - 3001938
277-2339-ND |
| Manufacturer |
Phoenix Contact |
3001938 |
| LED |
Yes |
| LED Voltage |
24VDC |
UK 6-FSI/C-LED60 - 3001939
3001939-ND |
| Manufacturer |
Phoenix Contact |
3001939 |
| LED |
Yes |
| LED Voltage |
60VDC |
PT 6-FSI/C Series
PT 6-FSI/C - 3212166
277-3212166-ND |
| Manufacturer |
Phoenix Contact |
3212166 |
| LED |
No |
| LED Voltage |
None |
Terminal Block Connector 2 Position Disconnect Black 8-20 AWG |
PT 6-FSI/C-LED 12 - 3212169
277-3212169-ND |
| Manufacturer |
Phoenix Contact |
3212169 |
| LED |
Yes |
| LED Voltage |
12VDC |
PT 6-FSI/C-LED 24 - 3212172
277-17453-ND |
| Manufacturer |
Phoenix Contact |
3212172 |
| LED |
Yes |
| LED Voltage |
24VDC |
PT 6-FSI/C-LED 48 - 3212175
277-3212175-ND |
| Manufacturer |
Phoenix Contact |
3212175 |
| LED |
Yes |
| LED Voltage |
48VDC |
PT 10-FSI/C Series
PT 10-FSI/C - 1088498
277-1088498-ND |
| Manufacturer |
Phoenix Contact |
1088498 |
| LED |
No |
| LED Voltage |
None |
Terminal Block Connector 2 Position Disconnect Black 6-20 AWG |
PT 10-FSI/C-LED 12 - 1088499
277-1088499-ND |
| Manufacturer |
Phoenix Contact |
1088499 |
| LED |
Yes |
| LED Voltage |
12VDC |
Terminal Terminal Block Connector 2 Position Disconnect Black 6-20 AWG |
PT 10-FSI/C-LED 24 - 1088500
277-1088500-ND |
| Manufacturer |
Phoenix Contact |
1088500 |
| LED |
Yes |
| LED Voltage |
24VDC |
PT 10-FSI/C-LED 48 - 1088501
277-1088501-ND |
| Manufacturer |
Phoenix Contact |
1088501 |
| LED |
Yes |
| LED Voltage |
48VDC |
