Will you kindly suggest the pins required for this Molex 18 pin (Minifit?) cavity?
Thank you for contacting DigiKey , this housing looks to be part number 23-0039012180-ND , I cannot tell from the picture what the pitch is , the one I listed is 4.2mm pitch , if this is correct here is a link for the contacts that will work in that housing , you will need to narrow down the search by wire AWG and contact finish you are looking to get .
