Would like help finding the correct replacement for this connector housing and the correct pins.
I believe the dimensions are 20mm/16mm/6mm. It has a half V shaped locking tab that plugs into the header. I believe the pitch is 3.96mm
Thank you.
matt.feil
Thank you for contacting DigiKey , from the measurements in the pictures this looks to be a 5.08mm pitch, I do not see that we have this exact connector the closest I am finding is part number WM9124-ND the contacts are in the link below , check data sheets to see if this will work for you .
Thanks Craig
