Identify 2-pin connector
Please see the attached pictures. I’m looking to find what connector this is so that I can order the correct pins, connector, and de-pinning tool.
Hi dax,
Please measure and report the contact pitch, P, (center to center dimension) as this is the most important dimension when searching for a rectangular type connector.
It’s probably the 0003062023.
Pitch is 3.68mm (0.145").
Associated contacts:
David, thanks. I went and checked with calipers, and you are correct, it is 3.68 mm pitch. Appreciate the help!
dax,
Looks like David found the best match to your connector.
I did a search also, and did not find a better match.
Let us know how it works out.
