Help Identifying Connector
Hello! I would appreciate any help in identifying what type of connector I need. I’ve done some research and it looks like maybe it’s a JST 1.25mm 5-pin connector but I’d like your input. It’s hard to measure the pitch with the tools I have.
Thank you!
Welcome to the Digi-Key TechForum bluna.
The first item would be the pitch. A 5pos connector with a 1.25mm pitch, would have a total width of about 1/4". Your connector is larger. Your ruler shows just under 3/8" from the first to the last contact.
This would be a total of about 9mm. Divide that by the 4 spaces, and you get about 2.25mm for the pitch.
These would be a blade type connector, but I did not find a match in our system.
Looks quite a bit like the 1.20mm pitch Molex Pico-EZmate 0781710005.
Mating connector is the 0781720005.
We also carry pre-crimped contacts on 300mm long wire for this connector, the 0797581010.
Thank you for the info!
Perfect! Thank you!
