Plating Color Issue on Phoenix Contact DIN RAIL
Sometimes, customers come to us with concerns over the plating color of Phoenix Contact DIN rail 0801681. The datasheet specifies a silver finish, but the product a customer receives appears yellowish. If this applies in your situation, here is some clarification from the manufacturer.
The yellow color is a result of the passivation treatment Phoenix uses, which helps prevent corrosion and increases the product’s lifespan.
This characteristic of yellow zinc plating is completely normal and does not compromise the performance or quality of the DIN rail. Rest assured, the product meets all necessary standards for durability and functionality.
Applicable Part Numbers
DigiKey Part Number Manufacturer Part Number
277-10191-ND 1207658
277-7262-ND 0801681
277-2293-ND 0801733
277-2297-ND 1201730
277-5375-ND 1207640
277-2064-ND 0807012
277-5358-ND 1206421
277-5504-ND 1206599
277-1207639-ND 1207639
277-16990-ND 1207650
277-7318-ND 5604187
277-7319-ND 5604188
277-5578-ND 0806602
277-7403-ND 3240262
277-5425-ND 0814681
277-3240571-ND 3240571
277-2123-ND 1207653
277-5592-ND 1207666
277-2291-ND 1401682
277-8227-ND 1206418
277-5432-ND 0801704
277-7265-ND 1401763
277-5379-ND 1201002
277-7266-ND 0801762
277-12716-ND 1204096
277-5553-ND 0801759
1207663-ND 1207663
277-12719-ND 1208018
277-7263-ND 1201714
277-7268-ND 1201798
277-5452-ND 0801377
277-5674-ND 1206434
277-5675-ND 1206586
1210006-ND 1210006
277-5466-ND 1201015
1204122-ND 1204122
5404669-ND 5404669
277-16992-ND 1210019
277-10877-ND 0801775
277-10192-ND 1207649
1207644-ND 1207644
1207646-ND 1207646
277-7264-ND 1401695
277-7401-ND 1204119
277-10190-ND 1207655
277-12718-ND 1207679
277-7267-ND 1201756
277-5614-ND 1207682
1207695-ND 1207695
277-5648-ND 1201028
